Tagged: 18.2, mechanical, Multibody, structural-dynamics, structural-mechanics
April 5, 2023 at 2:32 pmFAQParticipant
No, one cannot apply the tabular acceleration in rigid dynamics analysis. Both Acceleration and Standard Earth Gravity must be constant throughout a rigid dynamics analysis and cannot be deactivated. You may consider to integrate the tabular acceleration with time to get velocity and then use the tabular velocity boundary condition to apply the acceleration.
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to include effect of bolt pretension in a modal analysis?
- In a Modal Analysis of Mechanical, why aren’t the Participation Factors Summary under Solution Information displayed?
- Is it possible to perform a sine-on-random vibration analysis in either Mechanical or Mechanical APDL?
- ANSYS Mechanical: Vibration Housing Noise
