Tagged: 18.1, autodyn, contact, explicit, Explicit - AUTODYN, mechanical, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantNo, this support is not available in Explicit STR. Instead the user may define local coordinate system and use the displacement condition to constraint the out of plane displacements to impose similar condition.
