Is it possible to define constant amplitude nonproportional loading within the Mechanical Fatigue Tool?
Tagged: 19.1, fatigue, materials, mechanical, structural-mechanics
April 13, 2023 at 7:33 am
SolutionParticipantYes. You need to use a Solution Combination. See the attached example. The loading is a static load and a varying load. The static load is the axial load (e.g, could represent a preload). The varying load is a bending load e.g., could represent any varying load).
1. 2055951.zip
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Why is the unit of the elastic foundation stiffness N/m^3?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
