Tagged: 19.2, General, mechanical, structural-mechanics
April 13, 2023 at 7:32 am
SolutionParticipantYes, it is possible. This is the procedure to follow: 1.In Workbench go to “Tools” 2.Select “Options” 3.From the list on the left choose “Appearance” 4.Change/Modify “Edge Colors”: – a.“Free”, “Single”, “Double”, “Triple”, “Mutiple”, and/or “Meshed” as needed Additional information can be found in the ANSYS Documentation: ANSYS Documentation > Workbench > User’s Guide > Configuring ANSYS Workbench > Setting ANSYS Workbench Options > Appearance
1. 2056856.pdf
