June 6, 2022 at 9:58 am
FAQParticipantCyclic Region is compatible with Remote Point, but the Remote Point must be at the Cyclic Axis of Symmetry. You can check the coordinates of the Remote Point to confirm it, and if required, locate it correctly as per above condition.
