January 25, 2023 at 7:34 am
FAQParticipantThis can be done in Workbench Mechanical using User Defined Results. Please do the following: 1. In the Details view of the Analysis settings branch, under Output Controls section, switch “Stress” to “YES” 2. After solving (if needed), under the Solution tree, insert a “User Defined Result” 3. In the Details of the “User Defined Results”, and under Expression, enter “ENERGYPOTENTIAL” 4. In the Details of the “User Defined Results”, and under “Mode” write the mode number. If strain energy density (rather than strain enegy) is desired, use “ENERGYPOTENTIAL/VOLUME” for the Expression in Step 3 instead.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
