January 25, 2023 at 7:34 am
FAQParticipantDisplacement, stress, and strain are reported in the solution coordinate system (see RSYS command). The solution coordinate system for element quantities (e.g., stresses and strains) is the element coordinate system. By default, for solid elements, the element coordinate systems are global cartesian. For beam elements is based on the element alignment. The solution coordinate system for nodal quantities (e.g., displacements) is the nodal coordinate system. By default, the nodal coordinate systems are global cartesian.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
