Tagged: 19.1, fatigue, materials, mechanical, structural-mechanics
January 25, 2023 at 7:34 am
FAQParticipantThe safety factor reported by the Mechanical Fatigue Tool is the multiplier on the stress required to predict a fatigue life equal to the Design Life specified in the Details Window. The default setting for the Design Life is 1e9 cycles. Thus, if minimum calculated safety factor is 2.5, then the applied load can be increased by a factor of 2.5 and still achieve a design life of 1e9 cycles.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Why is the unit of the elastic foundation stiffness N/m^3?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
