In SpaceClaim, when I take section of the assembly, it is not recognizing all parts. How to identify the issue?
June 5, 2023 at 7:05 am
FAQParticipantThis is probably due to corruption in the geometry. To identify the issue, exit the section mode. In structure tree, go to body which was not recognized in section mode. Right click on the body and select ‘Check geometry’ option. This should highlight any corruption in that body. Remove/Repair the corruption.
