In Rigid Dynamics when using constraint equations, the units are not displayed properly in the worksheet.
Tagged: 19.2, mechanical, Multibody, structural-dynamics, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantQuestion: In Rigid Dynamics when using constraint equations, the units are not displayed properly in the worksheet. If you see the units of omega or velocity, the numerator shows 1 instead of sec. These are the units of the coefficient and they are displayed so that user can enter the value of the coefficient in correct units. If the coefficients are in wrong units, the Constraint Equation will be completely wrong.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
