In NX12, the Ansys menus appear, but the icons show broken image types, and the buttons are not selectable. Why might this occur?
Tagged: 19, CAD Imports, mechanical, structural-mechanics, UG
March 17, 2023 at 8:59 am
FAQParticipantNX12 will not load menu files (.men) of the same name, even if they are in different directories. This is a change in behavior from previous NX versions. Workaround: Change the name of the menu file by appending the appropriate version. Example: Rename C:Program FilesANSYS Incv190aisolCADIntegrationUnigraphicsNX11winx64startup UgToDSpace.men To: UgToDSpace190.men
