In modal analysis, the requested frequencies have been calculated which can be seen in the solution data. but the solver continues on to another “Lanczos cycle” without converging further. How to stop this?
June 6, 2022 at 9:58 am
FAQParticipantThis behavior is most usually due to a very ill-conditioned system. Try changing the solver from Block Lanczos (direct) to subspace. Subspace better handles indefinite matrices than the Block Lanczos (BL) method. This can be done in Analysis Settings -> Solver Type -> Subspace. Usually what is happening is that there is a disagreement between the number of modes to be found between what the BL found and what the Sturm sequence check finds. So a new BL cycle is done with a new shift, but then the same disagreement is found but in the opposite direction. the subspace does not perform a Sturm check by default, so it can bypass the issue altogether and ‘fix’ what is causing the ill conditioned model. But at the expensive of a possible less accurate model. There is also an option to turn off the Sturm checking for the BL method via the new LANBOPT command.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
- How to combine results of static structural analysis and harmonic analysis ?
