March 17, 2023 at 9:00 am
FAQParticipantYes, but components are not saved on the rst file. To allow Mechanical access to them, you need to save and resume the db file. The following approach should work: 1. save the restart files 2. save the MAPDL database. 3. issue RESUME on the first line of the Command Object.
