In mechanical interface, when I assign the material to the part, why does my material lib is blank even I define many of material in my project?
Tagged: 2019 R3, General, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantCustomer’s solution: The issue is caused by internal firewall strategy. After his IT colleague’s support, the issue is addressed.
