Tagged: 19, General, mapdl, mechanical-apdl, structural-mechanics
April 5, 2023 at 2:33 pm
FAQParticipantThis can be using simple commands, here’s an example for plotting equivalent stress on deformed mesh at a scale of 10. /DSCALE,1,10 /EDGE,1,1 PLNSOL,S,EQV
