Tagged: 17, Ansys nCode DesignLife, DesignLife, fatigue, General, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantThe difference between SweptSine and SweptSine2 loading is how the sine sweep information is entered. SweptSine uses a convention familiar to vibration test engineers (amplitude, start frequency, and end frequency). SweptSine2 uses a convention familiar to analysts (frequency vs amplitude).
