In ANSYS Mechanical, is it possible to change the maximum number of annotations allowed in the graphics window? The current limitation is 10, so for example, it is not possible to display more than 10 boundary conditions simultaneously.
June 5, 2023 at 7:04 am
FAQParticipantYes. The default maximum number of annotations is 10, but that default can be modified using the Tools options. Go to Main Menu > Tools > Mechanical > Graphics > Max Number of Annotations to Show
