In an XFEM analysis I get the following warning message: *** WARNING *** For crack with crack id 1 associated with cgrow id 1 the direction of crack propagation is such that the crack will cut the current crack tip element 2790 again. An element can only be cut once by a crack. Please check your results. What does it mean?
Tagged: 2019 R1, fracture, materials, mechanical-apdl, structural-mechanics
May 15, 2023 at 8:32 am
SolutionParticipantWhen you receive this Warning Message, an already cracked element is attempted to be cut a second time. Cutting an element twice is not supported in the XFEM. Accordingly, the respective crack is not grown. Instead, the solver procedes with the load application until the predicted crack growth direction changes such that a different (yet uncracked) element would be cut, or until the load is fully applied. (In doing so, the substep size is often decreased to the minimum possible, leading to very slow simulation progress and large rst files.) This situation can e.g. occur, when the crack gets deviated from its physically preferred crack growth direction (e.g. due to numerical inaccuracies). In the following crack growth step, the solver would most probably try to correct the former deviation. If the foregoing deviation was big enough, this correction might lead to the intention to cut the crack tip element for a second time (which is not allowed, as stated above). A possible cause for such numerical inaccuracies could be a too small stress evaluation radius (CINT,RADIUS) when using the maximum circumferential stress criterion (STTMAX) for crack growth direction determination. Please check the attached picture for illustration.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
