April 5, 2023 at 2:32 pm
FAQParticipantTo import HDF5 file, from the tree outline in ACP, right-mouse-click on ACP Model –> Import from HDF5 Comoisite CAE FILE In the opening window, set Import Model to be “Append” instead of “Overwinter”, if you have multiple HDF5 files. In R19.1 and later version, we can select element sets to apply HDF5 file. In the same window, to assign the HDF5 to specific surface, uncheck the “All Element” under “Scope”, and for “User Defined Set”, select the desired element sets. Element sets can be defined by user in Model by Named selections.
