In a topology optimization analysis with reaction force defined as a response constraint, the calculated force residual is always reported as zero. Why?
March 17, 2023 at 8:59 am
FAQParticipantTry scoping the force response constraint to the constrained nodes at the BC and not on the nodes where the force is actually applied.
