In a Rigid Dynamics analysis, when I overwrite the mass property of a body using the SetMassAndInertia() command, my result seems to be scaled up by 1000. For instance, I use the following: _myblockID = CS_Body.Find(_bid) _myblockID.SetMassAndInertia(10,0,0,0,0,0,0) I’m assuming that the solver will read in 10 kg for the mass. Performing a simple test involving gravitational acceleration, the force is 1000 times greater than what is expected. I am in mm,kg,s unit system.
March 17, 2023 at 9:00 am
FAQParticipantIf the active unit system is set to mm,kg,s, then the solver unit system will measure the mass in metric tons. Since 1 ton equals 1000 kg, the result will be scaled by 1000 if the appropriate conversion is not done beforehand. Keep in mind that command objects do not automatically scale quantities; they are units agnostic and take numerical inputs of both integers and floats. The usage of the solver unit system is not apparent because the solver output makes no indication of this, so we plan to enhance the command object header to reference the units used for the solver unit system.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- Presentation on shock analysis using response spectrum and transient dynamics
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
