March 17, 2023 at 9:00 am
FAQParticipantIn an ANSYS random vibration analysis, root-mean-square (RMS) values are referred to as “one-sigma” values. So, the RMS acceleration is the one-sigma acceleration. “G” refers to the acceleration expressed in terms of the gravitational acceleration. So “GRMS” is the one-sigma acceleration in terms of G. In /POST1, the calculated one-sigma accelerations are stored in load step 5. To obtain the one-sigma acceleration in terms of G (GRMS), simply divide the one-sigma acceleration values by the gravitational acceleration constant using the SET command. /post1 set,5,1,1/386.4 ! for BIN unit system
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- How to include effect of bolt pretension in a modal analysis?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
