If I define Isotropic hardening curves for two different temperatures and I run an analysis at a temperature between the two temperature curves, how will the solver utilize the data? Will the solver interpolate?
Tagged: 19.2, materials, mechanical, plasticity, structural-mechanics
April 13, 2023 at 7:33 am
SolutionParticipantThe solver interpolates for temperature between the defined temperatures values for isotropic hardening curves. However, the solver does not extrapolate, so for temperature outside of defined range, it simply uses the min or the max range defined. For such case, it would also give warning/error message in solver output. Please refer to attached sample case for more details to see how the material properties are handle at multiple temperatures.
1. 2057514.zip
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
