I would like to use a material property (eg tensile strength) in my definition for a User Defined Result in Mechanical. Is this possible?
Tagged: 13, General, Mechanical (f. Simulation), structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantNo you can’t get a WB parameter value from Mechanical. You can create a parameter in EngData and independently create a parameter in Mechanical. Then you can link these 2 parameters by an expression via a custom output parameter from Parameter Set.
