Tagged: 19, command level, documentation, General, mapdl, mechanical-apdl, structural-mechanics
April 5, 2023 at 2:33 pm
FAQParticipantYes, it is possible. This section of the documentation provides details on both the syntax to be used and the options that can be specified: ANSYS Documentation > Mechanical APDL > Operations Guide > 4. Running the Mechanical APDL Program > 4.1 Starting a Mechanical APDL Session from the Command Level This information can also be accessed by following this procedure: 1.Open the ANSYS Help Viewer 2.Click on Tools — > Go to Page … 3.Use the following link in “Enter Page Location”: help/ans_ope/Hlp_G_OPE3_1.html
