I would like to define multiple layers of Thin Solid elements (SOLSH190) with a thin sweep mesh control, but the Sweep Number of Divisions is disabled. Why is this so?
Tagged: 18.2, mechanical, meshing, preprocessing, structural-mechanics, sweep
June 5, 2023 at 7:05 am
FAQParticipantThis is due to a restriction on multibody parts. For multibody parts, only one division through the thickness is possible. For single body parts, you can define multiple elements through the thickness using the Sweep Num Divs control.
