I want to enable the GPU accelerator for a simulation involving a hyperelastic material model, but I seem to be activating Partial Pivoting Logic which precludes the GPU from being used. How can I use my GPU in conjunction with my current analysis setup?
Tagged: 19, hyperelasticity, materials, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantThe help states that Partial Pivoting Logic will be activated if the mixed u-P formulation is used (help/ans_dan/gpusupport.html#nvidiahardware). In order to prevent this formulation from being activated, provide a small value for the material incompressibility parameter, d (e.g., use d = 0.001). This will prevent the mixed u-P formulation from being activated by the solver and your GPU will also be used in the solve as well.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
