Tagged: 11, General, Mechanical APDL (f. ANSYS), structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantUnfortunately, no. If you had terminated it cleanly by creating the jobname.abt file in the working directory with the line TERMINATE, it would have been possible.
