I performed the pre-stress modal analysis in Mechanical. Why can’t I see the modal shape is based on the deformed static structural analysis?
March 17, 2023 at 9:00 am
FAQ
ParticipantIn Workbench post-processing, one can’t see the modal shape results based on the deformed results. If needed, you can get expected results display in MAPDL. Please notice that the frequency results in MAPDL are the same with Mechanical.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- Presentation on shock analysis using response spectrum and transient dynamics
