I notice that the 3rd principal stress is always zero in tension for SHELL181, SHELL43, and SHELL63 elements. This is not consistent with an analysis done in NASTRAN using shell elements. NASTRAN reports identical results with ANSYS for SEQV, S1, and S2, but S3 is truncated to zero in tension. Is this a bug or code limitation in ANSYS?
March 17, 2023 at 9:00 am
FAQParticipantThis is not a bug. The shell element is in a state of plane stress, so when ANSYS reports principal stresses, there will be one which is expected to be, and is, zero. The three principal stresses, output as S1, S2, and S3, are ordered so that S1 is the most positive (tensile) and S3 is the most negative (compressive). At the top and bottom of the shell surfaces, where transverse shear stresses are zero, there will always be a zero principal stress (in the direction normal to the shell face). For anywhere else through the shell thickness where there are nonzero transverse shear stresses, this may not be the case. This may explain some of the differences between ANSYS and NASTRAN. We are not aware of how NASTRAN may treat principal stresses in shells; however, we have not observed anything abnormal in the results reported by ANSYS SHELL181.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
