- All Categories
- Fluids - Postprocessing
- I have launched Envision 10.2.7 (b) loaded an .evsn file,and my Envision window panels are not showing. Only the graphics window is showing. When I go to Windows > Show Panels, nothing happens. Ctrl+S does not work either. How can I fix this?
- Show Panels, nothing happens. Ctrl+S does not work either. How can I fix this?" target="_blank" rel="nofollow" title="LinkedIn">
- Show Panels, nothing happens. Ctrl+S does not work either. How can I fix this?" target="_blank" rel="nofollow" title="whatsapp">
- Show Panels, nothing happens. Ctrl+S does not work either. How can I fix this?" target="_blank" rel="nofollow" title="reddit">
- Show Panels, nothing happens. Ctrl+S does not work either. How can I fix this?" target="_blank" rel="nofollow" title="facebook">
Tagged: 10.2, ensight, Envision, fluid-dynamics, General, licensing, Visualize Data
March 17, 2023 at 8:59 am
FAQParticipantEnVision has two licensing levels: free mode, and pro mode. In free mode, there is no panel on the left. EnVision works as a 3D viewer, but some controls are disabled. Any person can run the free mode, it doesn’t require any license. The Pro mode requires a license token. The Pro mode gives access to the panels and some extra features that resemble Ensight. When you launch EnVision, it should say on the top bar if it’s running in pro or standard (i.e. free) mode. At start up, EnVision will check if there’s a seat for the Pro version available. If there is, it will start in Pro mode. That’s the default. If you want to force the free mode, launch EnVision from the shell / cmd prompt with envision102 -standard EnSight users have a fixed number of seats of EnVision Pro for free. However, because of some changes in the license system between different versions, most users with an “old” license file (prior to 19.2) will not have the correct tokens in their license file. So, regenerating the license file and using the license manager for 19.2 will fix the problem. If a user does not not have the EnVision Pro tokens in their license file, EnVision Free starts up without the panel on the left. Once they switch to the R 19.2 license file and licensing system, the tokens are correctly checked out, and EnVision Pro will start automatically.
- ANSYS Fluent: Scene and Animation Creation
- ANSYS EnSight: Overview of Postprocessing a Fluent Case in EnSight
- ANSYS Fluent: Simulation of a Rotating Propeller – Part 2
- Display Multiple Plots in the Same Scene using Overlays in Fluent
- Use Different Modes for Saving Pictures in Fluent
- Creating a User Surface in ANSYS CFD Post-processing
- How can I hide the legend or colormap for a Fluent plot?
- How do I automatically export figures generated in CFD-Post from Workbench?
- Add Annotation to Graphics Display within Fluent
- How do I display a vector or contour and the mesh lines together via TUI command?
