I get below error while defining orientation selection set in ACP “The Two directions of rosettes are too similar”
Tagged: 19.2, composite, composites, materials, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantThis issue comes when two or more bodies which are not connected to each other are defined in same orientation selection sets. To overcome this issue, please make multibody parts.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
