I cannot read a .anim file into the Animation utility: “Animate Program has encountered a problem and needs to close.”
Tagged: 11, General, Mechanical APDL (f. ANSYS), structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantIt may be that DSGStreamN.dll is not registered. You may try the following from a Windows command prompt: cd c:Program FilesANSYS Incv110ANSYSbinwin32 regsvr32 DSGStreamN.dll Then, retry the animate program.
