- All Categories
- Fluids - Postprocessing
- I am running the Compression Ratio Calculator and the second calculation fails repeatedly. I can only get the volume for the TDC position. Why is this happening and how can I work around it?
June 5, 2023 at 7:06 am
FAQParticipantIn versions 18.1 and lower Forte Launches the TDC and BDC calculations in parallel. The second calculation fails with a license error, but the error message is only visible in the log files. The workaround is to run the BDC calculation manually. This can be done by switching to no-hydro mode and running a single step with the initial run crank angle set to the BDC position. The calculated volume can be found in the thermo.csv file. If you load the file in Excel, the calculated in-cylinder volume appears in Column Q.
- ANSYS Fluent: Scene and Animation Creation
- ANSYS EnSight: Overview of Postprocessing a Fluent Case in EnSight
- ANSYS Fluent: Simulation of a Rotating Propeller – Part 2
- Display Multiple Plots in the Same Scene using Overlays in Fluent
- Use Different Modes for Saving Pictures in Fluent
- Creating a User Surface in ANSYS CFD Post-processing
- How can I hide the legend or colormap for a Fluent plot?
- How do I automatically export figures generated in CFD-Post from Workbench?
- Add Annotation to Graphics Display within Fluent
- How do I display a vector or contour and the mesh lines together via TUI command?
