I am outputting beam188 (cubic option) strains at integration points. Why aren’t the y values of the integration points aren’t on the centerline?
Tagged: 17.2, General, mechanical-apdl, structural-mechanics
June 5, 2023 at 7:04 am
FAQParticipantYou have large deflection turned on so the integration points are reported at the displaced location.
