I am entering data for a response spectrum analysis with acceleration input. I am using a CQC method and including missing mass effects. Question: The load data is being scaled. When I specify the missing mass effect ZPA, do I enter the raw data value or do I enter the raw data multiplied by the scaling factor?
June 5, 2023 at 7:04 am
FAQParticipantYou input the unscaled value for ZPA according to the MMASS command doc. Check the ds.dat file to make sure Mechanical isn’t scaling it when it writes the MMASS command though.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
