Tagged: 19.2, General, mechanical, structural-mechanics
January 25, 2023 at 7:34 am
FAQParticipantWe no longer have tools to write out Nastran bulk data deck (bdf). We can read in RBE2 or RBE3 Nastran elements into Mechanical using External Model, but we no longer export Nastran files. We import Nastran bulk data deck in Mechanical (via External Model) but not export it.
