May 25, 2023 at 7:29 am
SolutionParticipantThere are situations when user has to work with materials definitions that are not part of standard Ansys Electronics Desktop installation, for example proprietary or corporate definitions. Electronics Desktop recognizes two user-configurable library structures, called the User Library and the Personal Library. A root library directory is set up at installation. If none is specified, the default is the root Electronics Desktop directory. Standard materials definitions are stored in system library as Materials.amat file. The default location of the library is C:Program FilesAnsysEMAnsysEM
Win64syslib. To make user defined material library available, place the *amat file in either PersonalLib or userlib and specify the locations of the libraries in Options>General Options > Directories. Materials from libraries in both the User Library and Personal Library, as well as the System Library, are available for use in projects. Attachments:
1. 2043187.docx
2. 2043187.pdf
- Cloud Computing from Electronics Desktop
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- How to fix messed up Windows layout?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- What are the available boundary conditions in Maxwell?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to create and manage a queue of simulations?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
- Are solid losses and eddy losses the same in Maxwell?
