April 13, 2023 at 7:32 am
SolutionParticipantThe deleted (eroded) elements cannot be viewed in WB LS-DYNA GUI, You need to use LS-PrePost. In LS-PrePost you need to open d3plot files, click on VIEW from the top pull-down menu and then Show Deleted Elements. Then select FriComp to do a fringe plot. You will see the deleted elements in the fringe plot. Attached are the animations and the example I created to demo the process.
1. 2062743.zip
