January 25, 2023 at 7:34 am
FAQParticipantOne can use test data directly with the Response Function Hyperelastic model. This does not require any curve-fitting and will use the data exactly. One would separate and enter the uniaxial tension and compression data directly. One also need to define the compressibility either by including pressure-volume test data or specifying the material compressibility parameter. Details of the Response Function Hyperelastic model can be found in the ANSYS Help sections below: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v190/ans_mat/aQw8sq22dldm.html%23respfunc_mat Curve-fit to hyperelastic model: If one wish to perform curve-fitting on predefined hyperelastic models,then include both compression and tension in the “uniaxial test data”. Be sure to just put the values in ascending order, and there should be a (0,0) data point.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Guidelines of modeling a gasket.
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
