How to transfer the first mode shape from eigen value analysis to static structure for non-linear analysis?
Tagged: 19.2, General, mechanical, structural-dynamics, structural-mechanics
April 13, 2023 at 7:33 am
SolutionParticipantPlease refer attached document for details This Solution is created by our channel Partner Entuple
1. 2058525.pdf
2. 2058525.zip
