Tagged: mechanical-apdl, spaceclaim, transfer geometry
June 6, 2022 at 9:58 am
FAQParticipantSpaceClaim Direct Modeler can export the Ansys Neutral File .anf file format. The .anf file can be read by Mechanical APDL with no additional license needed.
