How to stabilize DPM evaporation rates of droplets in incompressible cases? How to remove dependency of evaporation rates of droplets from local pressure?
Tagged: fluent, fluid-dynamics, MP - Particle Tracking, multiphase, phase-change
January 25, 2023 at 7:17 am
FAQParticipantAccording to chapter 16.4.2. in the R19.1 Fluent Theory Guide, for the diffusion-controlled vaporization model the evaporation rate is calculated based on equations (16–101), (16–102) and (16–103). Equation (16–103) calculates the concentration of vapor in the bulk gas as a function of the local absolute pressure. In a case with a fluctuation pressure field this can lead to significant fluctuations of the evaporation rate (DPM Mass Sources). With the command (rpsetvar ‘dpm/absolute-pressure #f) the concentration of vapor in the bulk gas can be calculated as function of the operating pressure. This can help stabilizing the evaporation rates (DPM Mass Sources). Keywords: DPM, DPM Mass Sources, fluctuations, incompressible, evaporation, droplet, diffusion-controlled vaprorization
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
