How to split partially intersecting surface bodies into separate bodies without having the need to extend them in SCDM
March 17, 2023 at 8:59 am
FAQParticipantYou can use Combine tool with “Extend intersections” options enabled (in Options panel) to split partially intersecting surface bodies without having the need to extend them.
