General
General
How to specify end time and DTIME while simulating crack growth under a cyclic load?
    • FAQFAQ
      Participant
      The ending time doesn’t really matter – one can use default of 1 “second”. For question on DTIME, “CGROW,DTIME” ,that solution option parameter is not required – it’s helpful if you want more control over the timestep size for crack growth.
