March 17, 2023 at 8:59 am
FAQParticipantTo show dimensions that have been created in the main model space on a drawing sheet: 1. Expand the node for the desired view in the structure tree (i.e. Front View 1). 2. Right click the Annotation Plane and select Show Dimensions or Show All Dimensions.
