June 6, 2022 at 8:33 am
FAQ
ParticipantThis is possible by setting the number of parcels being injected proportional to Mass Flow Rate. In the following example particles will stop being injected into the domain after a certain injection duration time.
1/Define following expressions of the form:
switch = if(t < tinjection,1,0) tinjection = 0.015 [s] Mpdot = 9.41e-4 [kg/s] where tinjection is the particle injection interval and Mpdot is the required mass flow rate.
2/ Define the Particle Mass Flow Rate using an expression:
Mpdot*switch
3/Choose “Proportional to Mass Flow Rate” for “Number of Positions” and define particle number Np. Based on this setup, after starting simulation, N parcels are injected every time step until flow time >= tinjection N = time step size * Mpdot * Np Keywords: Particle, Injection, Time
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- What is the superficial velocity in multiphase flows?
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- How do I use porous media in a multiphase flow?
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
