March 17, 2023 at 8:59 am
FAQParticipantThe symbol used for a decimal separator (point or comma) is controlled by the Windows system settings. 1. Open Control Panel 2. Select Region and Language 3. Set Language to one that uses a comma as a decimal separator (i.e. German) 4. In Additional Settings, ensure that the comma is selected as the decimal separator 5. Restart SCDM
