Tagged: 2020 R1, analysis-techniques, mechanical, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantAttached solution picture shows option to see un-deformed geometry in wire-frame or shaded along with deformed geometry . Make note that deformation could be of scaled image , user also has option to select the scaling of deformed geometry in order to magnify .
