How to retrieve the Mass Moment of Inertia for volumes and Area Moment of Inertia for surfaces in ANSYS Spaceclaim Direct Modeler?
May 15, 2023 at 8:32 am
SolutionParticipantThe attached document 2057565.pdf gives the procedure to retreive the MMOI and AMOI in ANSYS SCDM.
1. 2057565.pdf
